Fethiye Posted July 7, 2021 Posted July 7, 2021 We have a Pyronix Enforcer wireless alarm. We might be going overseas for a few months. We don’t put the alarm on when we go overseas as we have cctv cameras which do the job we need but having replaced some batteries in pir’s recently I don’t really want any pir’s bleeping if the battery goes flat and I don’t know if that bleeping goes on and on like a smoke alarm - which might upset the neighbours. So is it possible to just “turn the system off” at the control panel ??? Quote
sixwheeledbeast Posted July 8, 2021 Posted July 8, 2021 Sensors don't bleep like a smoke detector, although it's possible the panel could if unset with an issue. Systems are not designed to be easily disabled, you would have to get up to every device. You should have your system serviced correctly and then use your system while your away. Quote
