We have an Accenta Gen 4 installation on a remote site. Nuisance warnings are annoying neighbours when we're not present. We can check whether a false warning for an intruder using CCTV.
Is there any way that we can switch off the Accenta via an internet solution?
Not sure what you're asking but if you want a solution you can disarm remotely by an app you need a newer panel
Thanks, guys
When you mention an upgrade or new panel, for an app, I assume that's a completely new setup?
In other words, there's no upgrade path to the existing Accenta kit?
That makes sense. If anyone has a compatible panel to the Accenta, I'd appreciate the info.
We're trying to secure a steel-panelled hangar, and requirements are different from a domestic setup (remote situation, exposure to elements etc.)
a what ?
You're from Hull, it's for those big noisy birds in the sky that you all throw rocks at when they pass over.
As said app isn't your problem , false alarms is what you want to solve
  • Upvote 1
Even if we can solve the false warnings, and the system is running OK, we will still need to switch off the system remotely.
