Eugene's DIY Den Posted July 21, 2021 Posted July 21, 2021 (edited) Something in the shed triggered my alarm last night. I'm thinking warm air currents in front of sensors or tamper contacts stick/slipping in this heat because of expansion/contraction or maybe bats. Does this panel differentiate between an alarm triggered by a sensor in a loop on a zone or the alarm triggered by a tamper going o/c on that zone? The panel just says a"Alarm" with the zone name. These false triggers are infrequent, maybe one or two a year, but always seem to happen in really hot weather. Edited July 21, 2021 by Eugene's DIY Den Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
sixwheeledbeast Posted July 21, 2021 Posted July 21, 2021 All systems should show alarm, tamper and (if radio) battery faults separately, it's an important part of diagnosing a false alarm event. Unless you wire something up wrong, an alarm is the sensor triggering be that a fault or the environment. Quote
Eugene's DIY Den Posted July 21, 2021 Author Posted July 21, 2021 3 hours ago, sixwheeledbeast said: All systems should show alarm, tamper and (if radio) battery faults separately, it's an important part of diagnosing a false alarm event. Unless you wire something up wrong, an alarm is the sensor triggering be that a fault or the environment. So should it specify zone number, name, followed by type of alarm triggering event? I'll check if this actually does happen and report back. If it doesn't, does it mean I have detailed alarm event reporting turned off in the menu somewhere? Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
PeterJames Posted July 21, 2021 Posted July 21, 2021 Tamper means exactly that the lid has come off something, or if hwired the cable may be damaged hkc will normally verbally tell you the fault "tamper zone 3" Quote
al-yeti Posted July 21, 2021 Posted July 21, 2021 44 minutes ago, Eugene's DIY Den said: So should it specify zone number, name, followed by type of alarm triggering event? I'll check if this actually does happen and report back. If it doesn't, does it mean I have detailed alarm event reporting turned off in the menu somewhere? My alarm normally faults on the day everyone goes out (as we get to door) or heat is a problem , original wiring was loft and PSU can't take intense heat lol failed yesterday Galaxy dimension was bullet proof PSU transformer Quote
MrHappy Posted July 21, 2021 Posted July 21, 2021 3 minutes ago, al-yeti said: PSU can't take intense heat as I said to the postman today, 20 is plenty... 1 Quote Mr Veritas God
james.wilson Posted July 21, 2021 Posted July 21, 2021 If its a pir in a shed that isn't a great idea 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Eugene's DIY Den Posted July 22, 2021 Author Posted July 22, 2021 (edited) 21 hours ago, PeterJames said: Tamper means exactly that the lid has come off something, or if hwired the cable may be damaged hkc will normally verbally tell you the fault "tamper zone 3" Yes, I just confirmed that. Edited July 22, 2021 by Eugene's DIY Den Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
Eugene's DIY Den Posted July 22, 2021 Author Posted July 22, 2021 20 hours ago, james.wilson said: If its a pir in a shed that isn't a great idea Can I use a double knock option on the same zone to only trigger an alarm after several operations of the PIR? 1 Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
sixwheeledbeast Posted July 22, 2021 Posted July 22, 2021 32 minutes ago, Eugene's DIY Den said: Can I use a double knock option on the same zone to only trigger an alarm after several operations of the PIR? You can, but you shouldn't. Quote
