Chef40 Posted August 5, 2021 Author Posted August 5, 2021 23 minutes ago, MrHappy said: if you have a job for all the radio tat.... a P48-Live is "free" panel for a little wired system in an outbuilding ? Thank you - you’re right but the customer says the shed is quite a long way from the house and anyways, they want to know if the alarm is sounding wherever they are… I can’t help thinking maybe your two system suggestion could be easiest but there would be some saving by creating two areas. Quote
Chef40 Posted August 5, 2021 Author Posted August 5, 2021 Given a single system with two areas, do you think an expander in the shed would be best? Quote
sixwheeledbeast Posted August 5, 2021 Posted August 5, 2021 64W-LIVE is the replacement, can get in kit form and break up. Quote
Chef40 Posted August 5, 2021 Author Posted August 5, 2021 1 minute ago, sixwheeledbeast said: 64W-LIVE is the replacement, can get in kit form and break up. Thanks… the issue is needing remote control (via app) to alert the user if the alarm is sounding. Thanks also for pointing out the keypads have zones… difficulty is it’s only two, hence thinking about the expander. Quote
al-yeti Posted August 6, 2021 Posted August 6, 2021 4 hours ago, Chef40 said: Thanks… the issue is needing remote control (via app) to alert the user if the alarm is sounding. Thanks also for pointing out the keypads have zones… difficulty is it’s only two, hence thinking about the expander. So overall not much worth protecting in there anyway? I suppose texe app system is still free? Quote
