Amit Posted August 23, 2021 Author Posted August 23, 2021 cables are all under floor and not under carpets Quote
MrHappy Posted August 23, 2021 Posted August 23, 2021 22 minutes ago, Amit said: cables are all under floor and not under carpets are you an alarm man or diy'er ? Quote Mr Veritas God
Amit Posted August 23, 2021 Author Posted August 23, 2021 yes Alarm, cctv and door entry systems retired now just helping a friend Quote
MrHappy Posted August 23, 2021 Posted August 23, 2021 1 hour ago, Amit said: yes Alarm, cctv and door entry systems retired now just helping a friend cool, usual thing of cable, device or controls if the cable is laid under the boards in a manner its trapped or damaged by a pipe, walking around on the floor above it may send the alarm batshit, something drawing lots of current, eg too much stuff on small controls may send the alarm batshit something odd is happening , check all the fuses are the correct rating eg- some mong may have a 5amp fuse where a 1amp belongs & when it draws too much current it batshits the alarm & does not blown the fuse with the tamper tied down gently press parts of the endstation pcb to see if it goes batshit check both continuity of all the all cables & then take them apart & check there is no shorts on every pair ? or change you mobile no. & find a new friend with a working alarm ? Quote Mr Veritas God
al-yeti Posted August 23, 2021 Posted August 23, 2021 3 hours ago, Amit said: retired now and got a new friend, thanks Mr happy Coolio Quote
