Hi all,
I am aware I can set a control timer, and have the system arm/disarm via it - but I can't see a way to make it use part set.
With Texecom Connect, I can set an app timer, and that can set "Part Set" but doesn't appear to let me select which of the three part set options I can have.
Is there a way to have a timer with a choice of part set?
TIA ?
Not possible currently AFAIK.
The only way I know you can arm a specific Part Arm is with SMS module and the "parm" command.
You can get outputs from if Part 1,2,3 is set/unset but no way to set 2 or 3 directly apart from above.
