Leebut Posted September 4, 2021 Posted September 4, 2021 I decided to upgrade my old Veritas alarm I installed several years ago for a new Texecom Premer elite so I can install some additional devices in the future I've installed the NEW controller, exterior siren and Remote keypad onto tested existing wiring, i've also installed two door contacts and two PIR's the issue I'm having once I powered it up and loaded the software as instructed, its saying there's system alerts then a rolling numbers of tamper faults from 001 through to 008, I've checked the obvious place for a fault on the exterior siren (for good measure I've adjusted the back plate screw and tamper screw on the internal cover all seem good), now because I've open the siren its showing exterior bell tamper that won't clear also the RKP says "call the engineer for a service" I can't find in the installation instructions how to reset these messages I've made sure the JP7 is on the centre and right pins all covers are on and I'm total baffled any help would be mightily appreciated Regards Lee Quote
james.wilson Posted September 4, 2021 Posted September 4, 2021 Have you wired it eol or double pole? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Leebut Posted September 4, 2021 Author Posted September 4, 2021 Hi James they're wired as EOL only two PIR on existing wiring, I'm expanding the system with three wireless capture PIR I bought with panel other two wired zones are magnetic door contacts lee Quote
james.wilson Posted September 4, 2021 Posted September 4, 2021 what are the diagnostics showing? id start and concentrate on 1 circuit then work from there Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Leebut Posted September 4, 2021 Author Posted September 4, 2021 Hi James the remote key pad won't let me go into any settings or diagnostics it continually flashes "call the engineer for service" and fault tamper 001 - 008 I've powered it down for today and going to take another look in morning, can't find anywhere in the instructions about clearing messages lee Quote
al-yeti Posted September 4, 2021 Posted September 4, 2021 1 hour ago, Leebut said: Hi James the remote key pad won't let me go into any settings or diagnostics it continually flashes "call the engineer for service" and fault tamper 001 - 008 I've powered it down for today and going to take another look in morning, can't find anywhere in the instructions about clearing messages lee So you need to put in the engineer code? Quote
sixwheeledbeast Posted September 4, 2021 Posted September 4, 2021 You don't say what model Elite Veritas is a double pole only panel so you have put resistors in detectors? If the keypad is unresponsive to the code then you have an issue on the network line, check panel LED's adjacent network for faults or for double address. Quote
Leebut Posted September 5, 2021 Author Posted September 5, 2021 12 hours ago, al-yeti said: So you need to put in the engineer code? I have used both engineer code and the user codes both don't work Quote
Leebut Posted September 5, 2021 Author Posted September 5, 2021 12 hours ago, sixwheeledbeast said: You don't say what model Elite Veritas is a double pole only panel so you have put resistors in detectors? If the keypad is unresponsive to the code then you have an issue on the network line, check panel LED's adjacent network for faults or for double address. I've installed a Premier Elite 64W LS Quote
