Guest Bruce Posted December 4, 2004 Posted December 4, 2004 Hi, Have an old //.National Installer.// Safewatch Custom Alarm and the keypad is going bad. //.National Installer.// says they no longer have that keypad, want to sell me whole new alarm. I need a #7604-018 Keypad for this system. If you can help, please email me at: BruceBubello@netscape.net Thanks much, hope I can find what I need.
C.S TEK. Posted December 4, 2004 Posted December 4, 2004 If you do manage to get a keypad it would probsbly be second hand and only a matter of time before that wares out aswell. I would suggest you go for the upgrade Bruce. Doesnt have to be with //.National Installer.// though, ring round and get a couple of quotes. Even if you keep your maintanance contract with //.National Installer.// they dont have to supply your new system. Also check your contract as u might have a rental system and they will have to replace it for free anyway. Where do u live? Chris Trade Member As Mr Kingswood said "Dont forget the 6 P's when installing.....Proper Preperation Prevents P*** Poor Performance!!!" John Kingswood(alais Nobby), Paul Earl Ltd 1985-2006
Deltaseven Posted December 4, 2004 Posted December 4, 2004 You have not said what is actually wrong with the keypad. If the number buttons are worn, it may buy you some more time if you change your code so that you avoid the worn buttons. (I don't know the system, so I don't know that this is the most likely fault) D7
Guest Posted December 4, 2004 Posted December 4, 2004 If you do manage to get a keypad it would probsbly be second hand and only a matter of time before that wares out aswell.I would suggest you go for the upgrade Bruce. Doesnt have to be with //.National Installer.// though, ring round and get a couple of quotes. Even if you keep your maintanance contract with //.National Installer.// they dont have to supply your new system. Also check your contract as u might have a rental system and they will have to replace it for free anyway. Where do u live? Chris 33693[/snapback] from the panel i'd say america
Nova-Security Posted December 4, 2004 Posted December 4, 2004 Anybody know what panel it is of the description ????? www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Guest Posted December 4, 2004 Posted December 4, 2004 not 100% sure but i think its a //.National Installer.// USA branded system,which i think ademco makes...but dont quote me on that..i think they also make a wireless version of it..but safewatch is def a //.National Installer.// brand in the usa..
abbz Posted December 10, 2004 Posted December 10, 2004 safewatch used to be the old focus range of //.National Installer.// panels if memory serves me right
misterg Posted December 11, 2004 Posted December 11, 2004 could be wrong but i thought safewatch was thorn's quirky software version of a galaxy type panel - don't know if a standard galaxy keypad would work. must be an //.National Installer.// engineer out there to enlighten us. Mister G
Guest Posted December 11, 2004 Posted December 11, 2004 could be wrong but i thought safewatch was thorn's quirky software version of a galaxy type panel - don't know if a standard galaxy keypad would work. must be an //.National Installer.// engineer out there to enlighten us. 34182[/snapback] nope...its a usa/canada panel tho im not sure if the newer keypads work on the old panels..and a standard galaxy rkp wont work on the thorn version as its encripted software..
abbz Posted December 12, 2004 Posted December 12, 2004 werent thorn galaxys called siteguard not safewatch?
