I have just fitted a Scantronic i-on10 with the KP01 Keypad.
All is working well but I have a question regarding the keypad backlight settings.
I can enable or disable the backlight by going into the local menu on the keypad. The instructions state that disabling the backlight at the keypad allows the settings in the installer menu to specify the backlight mode, these being On, Off, Timed & Brightness.
I have disabled the backlight in the local menu on the keypad but cannot find the backlight options in the installer menu. Following the i-on10 configuration guide my understanding is that the option should be under Dectectors/Devices, Wired Keypads, Edit Keypad & then Backlight.
Can any member offer any thoughts on what I am missing?
Thanks.
For reference: Reply from Scantronic support.
The keypad backlighting is controlled from the local menu on the RKP itself, not from the panels Installer menu as stated in error in the manual.
 Sorry for any confusion caused.
 Thank you for you feedback the manuals will be corrected.
Good job , I was meant to tell you that forgot lol
