j.paul Posted December 5, 2004 Posted December 5, 2004 No it beeps once and stays at attack and day>How old is the panel? At least 6 years I would try and default the panel, then see if it will programme again If not then could be a faulty PCB There are no stupid questions, but there are a LOT of inquisitive idiots.
Guest ubergeek Posted December 5, 2004 Posted December 5, 2004 I would try and default the panel, then see if it will programme again If not then could be a faulty PCB 33835[/snapback] OK I'll default the panel again and see what happens. Thanks for all the help!
Guest RICHL Posted December 5, 2004 Posted December 5, 2004 Im not 100% sure but I think your panel is older than your manual.
FASTCAR Posted December 5, 2004 Posted December 5, 2004 The original Optima Compact has 6 pre-programmed zones , ( an XM6 with chimes).
Guest ubergeek Posted December 6, 2004 Posted December 6, 2004 The original Optima Compact has 6 pre-programmed zones , ( an XM6 with chimes). 33866[/snapback] The manual says '6 zones plus PA and Tamper' btw I did a factory reset from engineer mode (via the SET key) - now the alarm arms itself but it still won't let me set up the zones. If it defaults to Program 1 then I might be ok
FASTCAR Posted December 6, 2004 Posted December 6, 2004 Using the user manual , try to set the second user code , if it wont let you , I would suspect you have the older , non programmable panel.
Guest ubergeek Posted December 7, 2004 Posted December 7, 2004 Using the user manual , try to set the second user code , if it wont let you , I would suspect you have the older , non programmable panel. 33946[/snapback] It won't let me. Well done that man. Out of interest when did they stop making the 'old' panels? Thanks for all the help!!
