Guest Mel Coulson Posted December 7, 2004 Posted December 7, 2004 Can anyone PLEASE HELP. We have just moved house and it has an "OPTIMA XM6" alarm fitted but there is no manual and I have no idea what the code is. How can I get an instrution manual, and can I cancel the existing code without knowing it , and install my own code. Many Thanks, Mel.
Guest Posted December 7, 2004 Posted December 7, 2004 I haven't got a manual to hand but I'm sure someone else will be along soon witth one of those. If you haven't got the code then there's not a lot you can do, you'll need an engineer to re-program the system and set the codes back to default, it's not a user function I'm afraid.
Brian c Posted December 7, 2004 Posted December 7, 2004 Ditto what Lurch has said, but here's the user manual. Optima_XM_user_Guide.pdf If you don't know......ask.
Guest Guest_Phil_* Posted December 20, 2004 Posted December 20, 2004 Can anyone PLEASE HELP.We have just moved house and it has an "OPTIMA XM6" alarm fitted but there is no manual and I have no idea what the code is. How can I get an instrution manual, and can I cancel the existing code without knowing it , and install my own code. Many Thanks, Mel. 33986[/snapback] It is against this forums rules to post defaulting information in the public forums. I hope that helps! good luck Phil
