Whiteside46 Posted March 11, 2022 Author Posted March 11, 2022 20 minutes ago, james.wilson said: If your getting 12v on your meter between bell trig and 0v the panel isn't driving the bell. Touching the bell trig to 0v in the panel proves this. Yeah that’s right. The old bell box must have been driven differently? Quote
Whiteside46 Posted March 11, 2022 Author Posted March 11, 2022 Solved it. When I started this post, I was looking at a way of disabling the current bell so I could remove the lid without it going off. I must’ve forgotten I’d been into the Engineer > Outputs > 1003 and switched it to not used instead of Bell. Switched it back and tested ok. should have done it all on one day. Stupid me. thanks for all your suggestions anyway guys. Have a good weekend. Quote
al-yeti Posted March 11, 2022 Posted March 11, 2022 2 hours ago, al-yeti said: So then if panel isn't faulty you may have changed the polarity by mistake Make sure it's neg and do a panel restart before testing it again And of course as above did you change bell delay .... So much the same changing polarity changing output type and so on all in programming Well done for remembering Quote
sixwheeledbeast Posted March 11, 2022 Posted March 11, 2022 Congrats on completing your 15 minute job. As I said originally there is no way to disable the bell, you have to get on with it. Quote
MrHappy Posted March 11, 2022 Posted March 11, 2022 2 hours ago, sixwheeledbeast said: Congrats on completing your 15 minute job. come on, I allow 30mins to do an EWD Quote Mr Veritas God
sixwheeledbeast Posted March 11, 2022 Posted March 11, 2022 15 minutes of tea drinking and paperwork? 1 Quote
MrHappy Posted March 11, 2022 Posted March 11, 2022 47 minutes ago, sixwheeledbeast said: 15 minutes of tea drinking and paperwork? 8:30 to 11:00 to change a 9651 to a p48 inc moving spur, with ewd + decoy 1hr for panel 30 mins each for ewd, decoy & rkp There's probably a further day to add other expanders & circuits & cat 5 for comms Quote Mr Veritas God
al-yeti Posted March 11, 2022 Posted March 11, 2022 56 minutes ago, MrHappy said: 8:30 to 11:00 to change a 9651 to a p48 inc moving spur, with ewd + decoy 1hr for panel 30 mins each for ewd, decoy & rkp There's probably a further day to add other expanders & circuits & cat 5 for comms 1hr travel each way? Setup Analyze Get pallets of doom in order 4hour? £150? Quote
MrHappy Posted March 11, 2022 Posted March 11, 2022 46 minutes ago, al-yeti said: Get pallets of doom in order you legend... Quote Mr Veritas God
