Hello, I've got a new house and I'm planning to fit a premier elite 48 pannel to the house and then run a data cable through existing ducting under ground to the separate garrage block. In there I was going to install a psu200xp and dual tech sensors to the expander. But I was wondering if I could fit a op16 and have it trigger a bell box if the panel is triggered. Has anyone done this. I know you could wire it as a scb from the panel but wondered if I could wire the remote bell box as a sab using the 200xp and op16?
Thanks in advance.
Posted (edited)
or just use the output & inputs that are already in the cabinet ?
Edited by MrHappy
Output modules were made EOL as expanders have 8 O/Ps anyway so they hardly got purchased. You also have no inputs on a OP16 so not suitable by itself.
It's possible to setup a either SCB/SAB bell from a PSU200XP, if you know how to program everything, yes.
Thanks for the reply, I forgot the 8xp expander board in the psu had outputs. I'm guessing I just need to program an output to go low on alarm.
