Tspoon1811 Posted April 5, 2022 Posted April 5, 2022 Hello. Please can someone suggest a wired mains powered bell box that I can use on my powermaster pm33. I have an expander module. I used to have a mc30 AC bell box linked to my powermax system which was ok but still requires back up battery and is wireless. I have decided it's time to upgrade to a powermaster pm33 hence my question. Thanks in advance Quote
james.wilson Posted April 6, 2022 Posted April 6, 2022 You wont find a mains powered device can you not cable from the panel to the SAB? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
PeterJames Posted April 6, 2022 Posted April 6, 2022 visonic do a wireless bell that you can put a 12v psu to Quote
sixwheeledbeast Posted April 6, 2022 Posted April 6, 2022 I don't believe the Powermaster has a wired box option, like the old one. You would have to cable it with alarm cable and use any standard SAB from it's expander module. You will have to check the 12V output current maybe use bell with SCB mode if required. Quote
al-yeti Posted April 6, 2022 Posted April 6, 2022 On 05/04/2022 at 17:29, Tspoon1811 said: Hello. Please can someone suggest a wired mains powered bell box that I can use on my powermaster pm33. I have an expander module. I used to have a mc30 AC bell box linked to my powermax system which was ok but still requires back up battery and is wireless. I have decided it's time to upgrade to a powermaster pm33 hence my question. Thanks in advance As swb says best option , wired bell in scb mode using expander board Quote
Tspoon1811 Posted April 11, 2022 Author Posted April 11, 2022 Thank you very much for your help and assistance and assistance on this. Thanks for the suggestion of wiring siren to expander module. Reading other posts, I was under the impression, even powering a siren in scb mode to the expander still needs battery power? On 06/04/2022 at 16:51, PeterJames said: visonic do a wireless bell that you can put a 12v psu to Hello. Are you talking about about mcs730 AC? I have this powered to the mains. It without a backup battery the panel shows siren as low battery. I have noticed this happens to my new visonic pm33 panel. Mains connection without connecting the back up battery raises low battery alarm. Quote
sixwheeledbeast Posted April 11, 2022 Posted April 11, 2022 Everything on an alarm has some sort of battery somewhere, if it's for primary or standby use depends on the component and/or the system. Standard wired alarm bellboxes have a built in rechargeable pack that will trigger the bell if the power is lost. If in SCB mode it will use this pack for the bell siren in all situations. Quote
Tspoon1811 Posted April 12, 2022 Author Posted April 12, 2022 On 11/04/2022 at 20:51, sixwheeledbeast said: Everything on an alarm has some sort of battery somewhere, if it's for primary or standby use depends on the component and/or the system. Standard wired alarm bellboxes have a built in rechargeable pack that will trigger the bell if the power is lost. If in SCB mode it will use this pack for the bell siren in all situations. Thank you very much for explaining this. It is much appreciated Quote
