Monte Carlo Posted May 18, 2022 Author Posted May 18, 2022 Yes, that is they. Quote I don't have a signature.
Jack b Posted January 21, 2023 Posted January 21, 2023 That looks like an old AFA panel. Usually they had those bell relays and the sigma low relay in a blue AFA drum fitted inside the premises. Are there any more photos of this system? Quote
sparky_75 Posted June 23, 2023 Posted June 23, 2023 This is an old AFA setup; possibly pre AFA Minerva days. AFA & Minerva merged together in 1969; but equipment remained to be installed with "AFA Burglar Alarm" and "AFA Security Systems" for quite a while after. With the involvement of EMI - the company name was officially changed during early 1973 to "AFA-Minerva - EMI". The installation pictured is a single circuit "G Type", the small box beloew the relay box has a red lamp on the top, beneath that a black knob (Circuit switch) and beneath that a barrel keyswitch. The red lamp warns you that a circuit is open, so don't turn the key! If the lamp was out when setting, it was safe to turn the keyswitch, setting the latch and bell circuit. Behind the panel, when the key was turned to "Arm", a metal bar rotated to wedge the above circuit switch - to prevent it from being switched off. The relay box above are the control relays - in most normal installations; this box was an AFA drum bell box (usually Black, or Blue). Relay on the LH side (above) is the Bells and Outputs relay, Centre Relay is the latch relay (in other versions of this box, this is a sealed Dublo relay) and far RH side relay is a low current relay - the circuit relay, energised by the end of circuit batteries. (3 flag cells). AFA did a multicircuit version of this - also available in Blue or Black; which could handle up to 10 circuits, and included a circuit test and panel meter. These boxes were often modifications to existing systems; where the drum would be removed; this box fitted and luxuries such as 24 hour Tamper and Panic circuits would be added, as well as a Lead Acid Battery and charger. There were still many of these installs in operation when I was at Thorn. We had loads on our books - and if looked after, were quite reliable. I removed one of the last ones in the midlands that was linked directly to a local police station. Not that it's any use to anyone, terminations - the first 12 are a drop down to the panel - wired in 12core. AFA-Minerva continued to make a Single G-Type and a Multi Circuit G-type (this could handle around 15 circuits and was the size of a large suitcase) until around 1976/77 - though still used Flag Cells - they also included electronics here and there as relay drivers in a bid to keep current consumption down. 1 Quote
sparky_75 Posted August 17, 2023 Posted August 17, 2023 On 15/05/2022 at 18:42, MrHappy said: google says marine use & railways.... They used them (originally) on the Railways for telecommunications - such as with remote telephones where there was no power and for block instruments to signal between signalboxes. I saw some factories - where they had their own internal phone system and exchange. Most - if not all early security alarm systems were battery only. It wasn't until BS4737 came in, that a requirement was made for them to be dual powered. Flag Batteries are about 40Ah; so you could get quite a bit out of them Quote
MrHappy Posted August 17, 2023 Posted August 17, 2023 1 hour ago, sparky_75 said: They used them (originally) on the Railways for telecommunications - such as with remote telephones where there was no power and for block instruments to signal between signalboxes. I saw some factories - where they had their own internal phone system and exchange. Most - if not all early security alarm systems were battery only. It wasn't until BS4737 came in, that a requirement was made for them to be dual powered. Flag Batteries are about 40Ah; so you could get quite a bit out of them Sadly most of the weird & wonderful stuff is gone. Most things are off the shelf stuff by the cheapest provider. Quote Mr Veritas God
PeterJames Posted August 17, 2023 Posted August 17, 2023 4 hours ago, MrHappy said: Most things are off the shelf stuff by the cheapest provider. So many people think that cheap trumps quality, and sadly those that understand quality works out cheaper in the long run are a dying breed. Quote
james.wilson Posted December 8, 2024 Posted December 8, 2024 Seems a popular topic? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
norman Posted December 10, 2024 Posted December 10, 2024 lol Quote Nothing is foolproof to a sufficiently talented fool.
