aouelali Posted July 9, 2022 Posted July 9, 2022 Hello all,i'm new in this field and im using a sensor Honeywell DT-7235T and i want to connect alarm with it,the sensor is working when i plugged but when it try to connect the alarm with it doesn't trigger !anyone can help !they are 4 pins 2 for power and 2 for alarm and there is also the tamper ?should i connect the tamper to trigger the alarm ?thanks for help. Quote
al-yeti Posted July 9, 2022 Posted July 9, 2022 56 minutes ago, aouelali said: Hello all,i'm new in this field and im using a sensor Honeywell DT-7235T and i want to connect alarm with it,the sensor is working when i plugged but when it try to connect the alarm with it doesn't trigger !anyone can help !they are 4 pins 2 for power and 2 for alarm and there is also the tamper ?should i connect the tamper to trigger the alarm ?thanks for help. What alarm panel are you connecting it to? Power goes to power Alarm goes to alarm Tamper goes to tamper However you may need eol , which can be explained if you give more detail of alarm panel Quote
james.wilson Posted July 9, 2022 Posted July 9, 2022 as above what you wiring it into? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
