3 hours ago, MichaelZoolingen said:
There is no wires in the way, the wire from panel and siren have i make a pictures.
Because the bell isn't a trigger type
You would need a relay for this , so the panel needs to trigger the relay and power provided to the bell via +and-. The two t terminals probably just a tamper switch
How ever if you look at the panel manual and buy a speaker instead it will work better for you and put on speaker terminal , don't however put this bell on the speaker output
I cant see what it says under the grey wire
and I cant see what it says under any of those terminals
Posted (edited)
All connections are correct   blue should go to the bell terminal
Apparently no one here worked on a galaxy G2 I guess?
Edited by Imnotshankled
  • Downvote 1
