6 hours ago, james.wilson said:
but when you wire it like it sounds all the time?
WHat does your meter read between bell and HO+
I have one of these  the connections are  + - and 2 tamper terminals
+ should go to 12 on panel
- should go to bell (output 1003) on panel
T should go to the t on panel
T should go to 0v
3 hours ago, sixwheeledbeast said:
If you read the question it sounds when wired like this, so it's a programming issue...
Likely something inverted or programmed wrong.
Read OPs message again
The issue they are having is they don't know where to put the siren -ve on the panel   they have been putting it in the 0v hold off connection and its been causing the alarm to go off
If it is a programming issue   go to engineer mode, select option 53  type in 03  and make sure it is set to bell and the state is positive
On 09/08/2022 at 16:14, MichaelZoolingen said:
but when i put blue cable in - then it will go off,
Yes thanks i have set siren on 1002, and now working good.
  • Thanks 1
