Manser Posted August 11, 2022 Posted August 11, 2022 Hi all Been doing alarm servicing for a little over a year now, mostly domestic with the majority of them being risco agility 2 and 3. Anyway one of our clients has an agility 2 but their keypad is playing up ( constantly draining battery's and also certain numbers are worn ) I'm just wondering if agility 3 keypads are backwards compatible with the 2 ? Basically I don't want to go all the way there just to find out it isn't only to have to hunt down for a agility 2 keypad . Any info would be much appreciated Quote
Imnotshankled Posted August 11, 2022 Posted August 11, 2022 (edited) 3 hours ago, Manser said: Hi all Been doing alarm servicing for a little over a year now, mostly domestic with the majority of them being risco agility 2 and 3. Anyway one of our clients has an agility 2 but their keypad is playing up ( constantly draining battery's and also certain numbers are worn ) I'm just wondering if agility 3 keypads are backwards compatible with the 2 ? Basically I don't want to go all the way there just to find out it isn't only to have to hunt down for a agility 2 keypad . Any info would be much appreciated No they are not backwards compatible you can only use the same version keypad with the panel version Let's just say I learned that the hard way Edited August 11, 2022 by Imnotshankled Quote
Manser Posted August 11, 2022 Author Posted August 11, 2022 24 minutes ago, Imnotshankled said: No they are not backwards compatible you can only use the same version keypad with the panel version Let's just say I learned that the hard way I thought this might be the case . Thank you very much Quote
Imnotshankled Posted August 11, 2022 Posted August 11, 2022 3 hours ago, Manser said: I thought this might be the case . Thank you very much Your welcome Quote
