1 minute ago, sixwheeledbeast said:
It's been a while but IIRC, TS690 was a domestic panel separate from the rest of the Network range.
Usually + denoted DD243/Prox tags (ie TS900+) but I believe the TS690 did support tags (or at least I remember a version that did), as it replaced the TS700.
Did you have tags before?
Have you installed the reader correctly?
Was it powered down when you installed it?
How are you learning the tags?
Are the tags or reader duff?
OOI how much was this museum find of a keypad?
Did you have tags before? NO
Have you installed the reader correctly? Seems it can only fit one way with the 4 prongs on the bottom
Was it powered down when you installed it? Installed in new keypad prior to wiring
How are you learning the tags? In menu options but just get a beep
Are the tags or reader duff? Tried around 10 tags so doubt all of them are duff. Possibility prox reader is faulty. Is there a way to test?
OOI how much was this museum find of a keypad? £35
  • Upvote 1
Maybe it's possible older versions of software didn't support it. Rarely seen a 690 mostly fitted 790+ upwards.
You'll find it can be mounted inside the keypad upside down...
You'd need a working one to test.
They usually beep/click at any tag programmed or not, but they are fussy and don't have a good range.
Would you know how i would check which version of software supported proximity fobs?
