Guest cons_uk2004 Posted December 12, 2004 Posted December 12, 2004 im new to this site and am in desperate need of an installation manual for the veritas r8 1996 board. i have the 1999 install guide but is not helping me. where can i find one or could someone please email it me many thanks
Brian c Posted December 12, 2004 Posted December 12, 2004 Sorry, but installation manuals are not given out on this site, only user manuals. If you post details of the problem you're having, though, we might be able to help. If you don't know......ask.
Guest cons_uk2004 Posted December 12, 2004 Posted December 12, 2004 have a veritas r8 installed in a friends house panel has been reset. cannot change the engineer code so assumin it needs the boss code to reset the pcb. was wonderin if there was any way to still program the zones so i can set it up for a part set but to do that i need the menu nubmbers from the 1996 install guide. i have the 1999 edition+user manual just cant find the 1996 manual anywhere. is there anywhere on the net in could get it from?
FASTCAR Posted December 12, 2004 Posted December 12, 2004 If you crash the panel, the factory settings for Part Set are 5,6,7 omitted .If the code is locked you are stuffed.Get your friend to buy a shiney new one , with extra features.
Guest cons_uk2004 Posted December 12, 2004 Posted December 12, 2004 for that ill try those. how much does a new panel cost? if the engineer code is locked and i have reset the system will it revert to the factory set default code?
FASTCAR Posted December 12, 2004 Posted December 12, 2004 No , there is an engineer option to lock the code, and it does just that , even if you default the panel.There are plenty of sites that will sell you a panel online.
Mister_Dave Posted December 12, 2004 Posted December 12, 2004 The usual price for a veritas online is usually about 50 quid. Dave Oxendale York based security systems engineer.
