Helping individuals with common problems with replacement battery for Accenta Alarm System.
To change the battery, unscrew the front panel. When removed the alarm will sound. Enter your 4 digit user code.
Carefully remove the front panel & place on the floor, ensure the screw is safely placed. Remove the two terminals, black first, then red making sure the terminals do not touch & remove/replace the battery, red first, then black. Please note, the panel is live with 240V for the transformer, ensure no components or cable terminals are touched.
Replace the alarm panel cover & screw. Reset the system by pressing X or reset button.
