Tspoon1811 Posted September 2, 2022 Posted September 2, 2022 Hello All. Firstly thank you very much for helping on this forum. i have learnt alot. I am currently installing a new visonic alarm system with VISONIC 0-1274-0 PIRs. I was wondering if someone can point to me where i should be positioning my PIRs. For the living room i was considering position D as its not pointing directly at the window and away from the radiator. For the open plan kitchen, i am a bit stuck for the best place due to windows, the patio door and the radiators. please can someone suggest if placing at 1 is the best location or should 3. 3 is within the 12m range of the PIR but i am not sure how accurate it would be given the proximity to the window. I can put a PIR in both 1 and 3 if people think its worth doing. I will put window sensors on the windows and the patio door. I realise the advise on here is from the goodness of peoples heart so i will not be holding any of you responsible should anything untoward was to happen to my house. Thank you very much in advance. floorplan ground floor.pdf Quote
james.wilson Posted September 2, 2022 Posted September 2, 2022 I'd go A 4 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sixwheeledbeast Posted September 2, 2022 Posted September 2, 2022 A4 unless there is a reason not to. Quote
PeterJames Posted September 2, 2022 Posted September 2, 2022 Did you not have a hard wired system before? I would have used the existing cables and replaced the hard wired system personally Quote
Tspoon1811 Posted September 2, 2022 Author Posted September 2, 2022 Thanks for the replies and feedback. My previous system was a visonic wireless system and after reading the posts on here I have realised the PIRs were not in the best places as it was fitted by someone else. Thanks for the position suggestions I will go A4 and position upstairs landing too. I thought above patio door wouldnt be a good option due to the the heat increase from the sun. Kind regards Quote
