Hi All
This is my 1st post here im looking for some advice
i have a RISCO GT600/601 Panel with Vo-COMM voice dialer fitted with my alarm system i am looking to get rid of my telephone line and more to virgin full fibre with voice over internet.
Virgin are saying to me 99% of alarms systems are ok with it as there digital phone line system (VOIP) is the same as a phone line its just digital you can even plug standard landline phone into it without issue but require me to confirm this before signing up i dont want to be left in a postition when they install it wont work.
can anyone help me answer this once and for all i have tried asking the company that install it but they are very little help they are just saying i need a whole new system etc i think this is just for the money.
thanks in advance for any assistance in answering this.
TL;DR - Yes upgrade system.
To expand because I am sure that's why you are here...
The panel is obsolete so no parts are available. As an aside, I am surprised your keypad is still functional, most I see now you can hardly read the screen or press the code in with ease.
Vo-Comm uses PSTN, you will not have this. The new router will probably have an ATA as you say but you will likely get issues with using this and it be unreliable, the same reason most fax machines are in the bin.
Virgin just want you to switch and deal with the issue later, but in fairness all newly designed systems should either be radio i.e. SIM card or IP i.e WiFi/Ethernet as options, be that private reporting or monitoring.
Even if you did it try connecting to the ATA and you were fortunate enough to have it work somewhat reliably, it would only take some router upgrade or power outage and it may stop working.
You will be responsible for making sure the ATA works and has line voltage so the Vo-Comm can dial, your PSTN provider currently do that -- with ATA if the router is powered off or crashes; then no line/no message.
These types of private reporting are not too reliable, so you may not care about it only working some of the time, there is no polling so who knows if it will work when you need anyway.
I would recommend a system with GSM comms  however if you don't want to get a sim card   or if you don't want to do that  you can use IP comms   often incorporating app
Some good systems for this are pyronix, orisec, and HKC
Mobile signals can be jammed and IP could still have downtime or an attack.
Both the path or the manufacturer are irrelevant, the only way you know if a signal will be received is if it polls (uses/tests) the path regularly.
Orisec can detect line failure    as I often get calls where a customer switches off the router and the alarm gets a fault
not the same as polling and only any use when unset though
local failure reporting when armed would be a bit pointless
For commercial yes but for a small domestic how often would that happen
and how many customers are willing to pay £75 a year for commercial monitoring
You do get a panel offline message if the panel is disconnected from the Internet but that can take up to a hour to receive
And in fairness any sort of external notification is a blessing  as most systems I work on are just bells only  when they really should have monitoring   or they had monitoring but cancelled it
And for that 1% that it can fail doesn't make the other 99% not worth it
And be honest  what is the likelyhood for someone to attack a wifi network and then break into a house at the same time or when the wifi is out to just to break into a house
