Adam0Enya Posted October 23, 2022 Posted October 23, 2022 (edited) I have a pyronix euro mini hardwired system which I'm trying to connect a UR2-WE receiver to I can add additional wireless sensors. How do I wire in the UR2, and secondly, how do I set up on the alarm the UR2 Edited October 23, 2022 by sixwheeledbeast fix topic title Quote
Imnotshankled Posted October 23, 2022 Posted October 23, 2022 (edited) 5 hours ago, Adam0Enya said: I have a pyronix euro mini hardwired system which I'm trying to connect a UR2-WE receiver to I can add additional wireless sensors. How do I wire in the UR2, and secondly, how do I set up on the alarm the UR2 You wire the 2 on board zones to the panel, fault to a 3rd zone and follow the manual to add detectors Edited October 23, 2022 by Imnotshankled Quote
Adam0Enya Posted October 24, 2022 Author Posted October 24, 2022 20 hours ago, Imnotshankled said: You wire the 2 on board zones to the panel, fault to a 3rd zone and follow the manual to add detectors Thanks for the advice! Are you able to draw a diagram as I am not so clued up with it. Also, how do I program via the keypad to recognise the sensor is for entry exit? Quote
Imnotshankled Posted October 24, 2022 Posted October 24, 2022 6 hours ago, Adam0Enya said: Thanks for the advice! Are you able to draw a diagram as I am not so clued up with it. Also, how do I program via the keypad to recognise the sensor is for entry exit? I would recommend getting a engineer in to wire it if you are confused But I hope this helps wire output a to zone 8 Wire output b to zone 9 And wire fault output to zone 10 using the provided diagram Connect 12v and 0v to panel 12v and 0v Connect arm to pgm on panel Quote
