Tas Posted November 22, 2022 Posted November 22, 2022 HiJust installed a Texecom premier elite 24 metal case with an expander at a distance from the panel.Just need to know if I can add 2 bell boxes to the expander and what connections to use on the expander to add them.Also Just to let you know there are no other bell boxes attached to the panel, but attaching them to the expander if possible would make cabling a lot easier due to the distance.Thanks for any help. Quote
MrHappy Posted November 22, 2022 Posted November 22, 2022 48 minutes ago, Tas said: HiJust installed a Texecom premier elite 24 metal case with an expander at a distance from the panel.Just need to know if I can add 2 bell boxes to the expander and what connections to use on the expander to add them.Also Just to let you know there are no other bell boxes attached to the panel, but attaching them to the expander if possible would make cabling a lot easier due to the distance.Thanks for any help. Powered expander ? Quote Mr Veritas God
MrHappy Posted November 22, 2022 Posted November 22, 2022 2 bells some distance from the controls connected to this- no, the small item within or with a local psu, yes what sounder ? Quote Mr Veritas God
sixwheeledbeast Posted November 22, 2022 Posted November 22, 2022 If you want to have SAB's then you need a PSU200XP. If in the quieter SCB mode then possibly but you will have to check your current isn't overloading the panel. You'll need to program the outputs and input correctly or it will FTO correctly. Quote
Tas Posted November 23, 2022 Author Posted November 23, 2022 Thanks for your help and advice noted. I think I am going to have to rethink the setup. Quote
sixwheeledbeast Posted November 23, 2022 Posted November 23, 2022 I did mention this in your Veritas thread, panels generally only have enough capacity to supply themselves, a keypad, sensors and one SAB. The maximum current that can be supplied by it's power supply is not always the limiting factor, you do calculations based on standby battery capacity. Quote
Tas Posted November 23, 2022 Author Posted November 23, 2022 Thanks I'm going to look at a Texecom PSU200XP, Quote
Imnotshankled Posted November 23, 2022 Posted November 23, 2022 21 minutes ago, sixwheeledbeast said: I did mention this in your Veritas thread, panels generally only have enough capacity to supply themselves, a keypad, sensors and one SAB. The maximum current that can be supplied by it's power supply is not always the limiting factor, you do calculations based on standby battery capacity. If you have 2 bells there is a low current mode on most new texecom SABs to let you get away with this Quote
