Hi,
     I have an old GT 601 Alarm system that is not working ?  I am not an installer just moved in. I wish to shut it down, I have the Engineers code and user code  but worried if I shut it down, the outside bell will sound?  Does the Outside bell have internal batteries? And can I power it down completely.
thanks
Terry B
That is correct.
With a fully operational system if you power down the inside the siren will activate.
Fully decommissioning a system usually involves ladders and earplugs.
They are designed that way so a burglar can't disable them easily from the inside.
1 hour ago, Tab said:
Hi,
thanks
Terry B
2 ways of doing this
Option 1
let your neighbours know, kill power to panel and wait 15min for the battery to die
Option 2
Get a ladder, open bell, disconnect battery and power down system
2 hours ago, Imnotshankled said:
Option 1
this will work for a few months but the battery isnt dead just the timer has shut it off. What it will do when it does start to go flat is anyone guess
  • Upvote 1
On all my experience nothing will happen and its a matter of hours not months
The comfort LEDs will flatten the battery's remaining charge
Posted (edited)
A Radio Delta Bell needs powering down properly....
Edited by MrHappy
