MattKini Posted December 30, 2022 Posted December 30, 2022 Guys, i am trying to setup a Videofied system, sending signals with pictures to Arcmon. They’ve been very helpful however i cannot get the bloody signal sent through basically i have setup the monitoring station settings, gave it server settings, gave cellular settings (although i am not sure whats SMTP one) still no luck used pay as you go, used o2 pay & go and m2m cat 1 please help before i smash this thing and burn it in my garden. I have 3 panels!!! these are for sites with no power. Battery powered only Quote
PeterJames Posted December 31, 2022 Posted December 31, 2022 Assuming you are forwarding pictures by email you need to use the smtp settings for o2 these are the outgoing settings (you would be better off using a contracted sim over payg imo) if the arc is using an Immex server then its the ports that need to be open on the SIM and thats when it gets tricky with PAYG https://smtpimap.email/o2-co-uk-smtp-imap-email-settings.html O2 SMTP settings Quote
