Hi all
I've just been trying to demo out my predominately wireless ION-40H system. The only part which is wired, is the sounder.
Most of the connections have a direct label in the control panel, however, i'm getting confused over the ENG input which appears on my siren. The manual says, output of type "installer on Site".  However, i cannot locate a relevant connection on my control panel
I've attached manual screenshots of both the bell inputs and my control panel diagram.
Any advice is much appreciated.
Thank you
image.png.55d0ee2508d5015c8e246dad364dbedd.pngimage.png.9de3fe179a032340978403b604952990.png
8 hours ago, rpatel2 said:
@sixwheeledbeast thank you. I will install without it.
As swb says stick a wire on it , and if you ever want to disable tampers some bells require to be connected temporary to 0v or something like that , then you can open bell without the siren going off or something like
