Changed the battery today and my alarm is stuck in tamper mode .Power LED light red
As is the tamper LED no other light on. Can another advice how to get my panel working.
Thanks
1 hour ago, sixwheeledbeast said:
It could be anything but as I say most likely the lid not on correctly.
You'll need a multimeter and know how to use it, if it's something else.
As 6 you still have a tamper fault. the word fault is wrong here as you caused the tamper by opening parts.
Once all faults/errors are clear it will reset.
