Jacqui Posted January 17, 2023 Posted January 17, 2023 Changed the battery today and my alarm is stuck in tamper mode .Power LED light red As is the tamper LED no other light on. Can another advice how to get my panel working. Thanks Quote
sixwheeledbeast Posted January 17, 2023 Posted January 17, 2023 If it's locked out, fix the tamper and press reset? Most likely the lid if you've been in there. Quote
sixwheeledbeast Posted January 17, 2023 Posted January 17, 2023 It could be anything but as I say most likely the lid not on correctly. You'll need a multimeter and know how to use it, if it's something else. Quote
james.wilson Posted January 17, 2023 Posted January 17, 2023 On 17/01/2023 at 21:49, sixwheeledbeast said: It could be anything but as I say most likely the lid not on correctly. You'll need a multimeter and know how to use it, if it's something else. Expand As 6 you still have a tamper fault. the word fault is wrong here as you caused the tamper by opening parts. Once all faults/errors are clear it will reset. Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
