Hello, first time poster here looking for some help and advice please.
I have a Pyronix Euro46 SM installed which seems to be a pretty decent set up?
However seems to be prety much locked down by the installer so needs a call out for almost any issue.
I was wondering if there was a way to lift any of these restrictions myself or if there was a good local engineer anyone could recommend that could lift some of these for me or go back to the insatlling engineer (which I would rather not!).
Also could do with someone looking at the CCTV system but guess that will be another post.
Many thanks in advance :-)
Alarm companies carry the liability for your system, thats why its locked. If you waive this then you may find a company that will allow it.
Bear in mind you could change something that you think is a good idea that could prevent correct operation or make it non compliant.
  • Upvote 1
QFA it wouldnt be a very secure security system if it was open for anyone to change the settings would it. You could buy a diy system if you wanted something that you could change yourself. It all depends on how bothered you are about it working if there was a breakin which is sort of the point in the first place
4 hours ago, f1refly said:
Any recommendations for good, honest, engineers around Manchester?
Nah manc's are all wrong 'uns
