Guest Guest_steve_* Posted December 15, 2004 Posted December 15, 2004 I wish to replace the keypad on my Scanatronic 9800. If I enter the engineer code can i then simply swap the keypads over or do i need to power down the system?
Deltaseven Posted December 16, 2004 Posted December 16, 2004 I wish to replace the keypad on my Scanatronic 9800. If I enter the engineer code can i then simply swap the keypads over or do i need to power down the system? 34726[/snapback] You need to enter "0" then engineer code. The panel will beep until the end-station is opened. Then you can swap the keypads over. You can do it live if you really want to - just be careful not to short any of the wires. And don't forget to set the dip switches to match the RKP you are replacing.
Guest Guest Posted December 16, 2004 Posted December 16, 2004 You need to enter "0" then engineer code. The panel will beep until the end-station is opened. Then you can swap the keypads over. You can do it live if you really want to - just be careful not to short any of the wires. And don't forget to set the dip switches to match the RKP you are replacing. 34747[/snapback] Thanks.
Guest bazzer Posted January 7, 2005 Posted January 7, 2005 Thanks. 34751[/snapback] i have done it live with out the eng code it can be done its just how good are you
