How to wire Odyssey 3 to Power 832
Guest rafal
Hi
I want to connect Odyssey 3 to Power832 /with 2 expanders/.
Odyssey requires:
+VE supply
-VE bell
-VE tamper
0V
-VE stobe
PC5015 has only Bell Output.
Could you advise on wiring plese.
Have I chosen the wrong bell box?
Thanks in advance.
Rafal
Never wired Odyssey 3 to Power832, but maybe this works:
+VE Supply -> AUX+
0V -> AUX-
-VE Bell -> Bell-
-VE Strobe -> Bell-
-VE Tamper -> Expander TAM
or
-VE Tamper -> any available Zone with resistor in series.
Hi
Odyssey requires:
+VE supply
-VE bell
-VE tamper
0V
-VE stobe
Thanks in advance.
Rafal
34749[/snapback]
I think you may have a non-UK version of the Power 832. It is not ideal, but you may have to connect +VE and -VE to Aux + and -, and use the programmable outputs to connect to Bell- and Strobe -. You could then use tamper return to switch a relay on a 24hr zone to set up SAB tamper. Just be aware that you will be putting a high load on the AUX circuit - check the load in alarm to ensure that you will not blow the Aux fuse. If you are at all unsure on how to do this, then contact a local installer.
D7
You need a relay to get the tamper to work on the Power Panels if Using Odyssey 3 sounder
Strobe goes on PG2 programmed as [10] System Event...
Non of the DSC Power panels have a tamper return like UK Panels it use's a resistor instead ;)
Thanks for all suggestions
I will have a go tomorrow.
Rafal
