Ade G3 NVM Reset
Guest carlbeardsmore
I have got a G3 panel that is showing a tamper fault even though I have wire linked the tamper from the zones input, remote keypad tamper input, and the sounder tamper input. (and pushing the control panel tamper switch)
Because of the tamper I cannot use the reset twice at power up to clear the NVM. ( The Remote key pad seems locked out.)
I have also tried a spare keypad.
Could anybody let me know how to clear the NVM without using the keypad?
cheers Carl
I'd be more concerned with the fact you can't clear the tamper.
I assume when you say "I have wire linked the tamper from the zones input", you mean you have linked out the two tamper terminals and not connected the tamper terminals to zone terminals. Have you linked out the PA terminals?
If you have done all of the above, it sounds like dry joints on the pcb.
Post your location or check the yellow pages and a professional will be able to help you
If you don't know......ask.
Guest IM_Alarms
Check the fuse that powers the RKP.
Yes, the "I have wire linked the tamper from the zones input" should have read
I have wire linked the tamper for the zones input. Sorry that was a typo.
Yes, the tampers are all linked, plus the PA. I have aslo check all the fuses whcih are ok. The remote keypad lights up, shows tamper even though the tampers are all linked(with the panels spring pushed down at the same time).
I have checked all the joints on the board . There is continuty from the pcb screw terminals right back to the uPC on the board.
I have had this before after a power cut while the battery was dead on my old optima 2 plus panel. I had to do a NVM clear to clear the tamper on that.
I thought that I could try and do the same on my new G3.
cheers Carl
I thought this was a restricted installers/members area only. Hence adding to the info given by previous posts on this topic. - Apologies if too much detail provided.
No objections if comments removed.
ARJ
A nearly retired previous installer !
35332[/snapback]
No, this forum can be view by any member of the public that registers.
Access to the trade forums can be obtianed here
ARJ
35332[/snapback]
No objections at all ;)
Welcome to the forum ARJ
You'll find it an excellent place for advice. :)
If you click the edit button under your post you can remove them yourself.
The areas that you can see now are viewable by anyone, but you have to registered to post.
Also, there is no installer verification process unless you apply to become a trade member, in which case your identity is checked and you can then post technical information in the registered installers area, (which isn't viewable by Joe Public as this is).
