Quick !!!!
Guest IM_Alarms
Guest IM_Alarms
I'm trying to remember the make / model of a pir sensor which has a distinctive round philips screw holding the front on, which pulls straight off , leaving the baseplate with just a terminal block in it?
I need it for a modified takeover specification i'm working on now. Ta
also, can you recognise a sensor which has a removable plastic strip across the top, which has a single screw behind. At the bottom of the sensor is a round lens area which is flat.
Ta again
Must remember to bring my notes home next time.
:yes:
Guest IM_Alarms
I think the Alrmcom sound like the one, the plastic screw fixing has an led in it (well a clear, part for the led light to travel along)
Wasn't that the one that was made for Gardner Security by Alarmcom, It had a black mirror lens :wacko:
Guest IM_Alarms
I'm trying to find a picture of an alarmcom sensor on-line to confirm it. Anyone know anywhere as I,ve tried all the usual suspects!
Thanks guys for helping, I might get an early night now. :no:
This is sad but I had one in the office, its was called a Gardiner Sabre Plus :w00t:
And now here are the pics... ;)
