Securing alarm cable to UPVC window?
Guest rafal
Hi all,
What do you guys use to secure alarm cable on to plastic window frame?
Superglue?
TIA
Rafal
Personally, I would rather use single cable trunking than glue.
:yes:
34812[/snapback]
Id rather see nicely done self adhesive micro trunking used.
I'm with Brian and Rich , go with a self adhesive mini trunking. :yes:
34814[/snapback]
Thanks,
What size is that mini/micro?
Rafal
Sorry Rafal mistake in my message before
mini trunking in two sizes:
size 1- 3-5.5mm
size 2- 5.5-10mm
WOAH!!!
Hold on there!
Wheres this micro trunking coming from, I've never heard of it.... smallest I've ever bought is 9*16.
Where does one get this single cable trunking then?
You can get a single cable type trunking that is only just big enough to sqeeze a single 6 or 8 core in, i am assuming the chaps are talking about this. It doesnt look like trunking till you have a cable in it, if that makes sense?
Im just not sure about the physical size of it but im sure its self adhesive also.
Yep, I've managed to get 2 6 cores in a piece once but wouldn't want to do it again
I usually get it from my electrical wholesaler in Nottingham. Most manufacturers do it, just not many suppliers bother stocking it.
