Hi am trying to get a deltabell working with my new risco lightsys plus panel I have set the bell to neg trigger and the strobe to neg trigger and connection to panel OU1 NO=Bell and 0U2 trigger but when the alarm is activated  I don't get any sound or Strobe from the deltabell can any 1 help pls here's a pic from the bell wiring
You need to have the switch closed for the bell to operate correctly. (or link it with a jumper on the pcb)
Hi thanks for getting back to me where do I place the jumper on the bell PCB please as I can't see a option to disable the tamper
Kind regards
Naeem
Kind regards
Naeem
1 hour ago, Naeem ahmed said:
Hi thanks for getting back yes it's on the panel
James is pointing out that your connecting to a relay which unless wired correctly will do nothing
Assuming the relay is triggered on alarm the no can stay in the bell trigger , but the c (common needs to connect to negative or minus or -ve ) that way when the alarm triggers it will connect the bell trigger to the negative it requires to ring it
Strobe I am not sure , the other outputs are programmable perhaps and you need to look at menus what they can do
Actually opto relays , I couldn't be bothered to see what and how they work in the panel other than that optical relays work similar
