4 hours ago, al-yeti said:
James is pointing out that your connecting to a relay which unless wired correctly will do nothing
Assuming the relay is triggered on alarm the no can stay in the bell trigger , but the c (common needs to connect to negative or minus or -ve ) that way when the alarm triggers it will connect the bell trigger to the negative it requires to ring it
Strobe I am not sure , the other outputs are programmable perhaps and you need to look at menus what they can do
Agreed can you post a pic of the panel wiring
Actually opto relays , I couldn't be bothered to see what and how they work in the panel other than that optical relays work similar
Opto relay is electrically isolated can't see the point on board tho unless it's known the board has shit loads of noise on it
3 hours ago, Naeem ahmed said:
Hi thanks for getting back to me I will send picture of panel and wiring when I get home thankyou
Kind regards
Naeem
Hi here is a pic of the panel wiring
Hi here is a picture of panel wiring bell trigger is in white and yellow is strobe
Hi thanks sorry for getting back late the bell is working now but I can't get the strobe to work when I do a test between the negative and strobe it works but it doesn't work when alarm is ringing I got it in ou2 and program it in outputs but still nojoy
