Naeem ahmed Posted May 14, 2023 Author Posted May 14, 2023 On 14/05/2023 at 19:40, james.wilson said: must be output problem either blown output or programmed wrong Expand It's a brand new panel will check again the programing thanks On 14/05/2023 at 19:32, Naeem ahmed said: Hi thanks sorry for getting back late the bell is working now but I can't get the strobe to work when I do a test between the negative and strobe it works but it doesn't work when alarm is ringing I got it in ou2 and program it in outputs but still nojoy Expand Quote
al-yeti Posted May 15, 2023 Posted May 15, 2023 On 14/05/2023 at 19:32, Naeem ahmed said: Hi thanks sorry for getting back late the bell is working now but I can't get the strobe to work when I do a test between the negative and strobe it works but it doesn't work when alarm is ringing I got it in ou2 and program it in outputs but still nojoy Expand What did you programme it as , you have a meter to see what output is doing? Quote
Naeem ahmed Posted May 15, 2023 Author Posted May 15, 2023 Hi I programmed it again and it's all working great now thankyou for all your help Kind regards Naeem Quote
