garnayrob Posted May 17, 2023 Posted May 17, 2023 Hi, I've just hard wired a Pyronix DeltaBell (with backlight) to a Pyronix enforcer panel, but it's not working. It was previously working fine with the same panel at another location. This time, I have not wired the tamper circuit (I removed the switch), as it's up high and the fitting surface is not particularly great. I did a reset on the panel, so the Z33 for the tamper is not active. Endstation ouput/bell output is set to 014 / Siren Any. I've only fitted 3 wires as follows: STB on siren to STB on the panel Bell on the siren to Bell on the panel 12V+ on the siren to +12v on the panel When the alarm is triggered, the internal siren works fine, the outside siren does not. I don't think the comfort lights are active either? On the siren, the battery is enabled (J8 jumper is connecting pins 1+2) on INT and the sounder cable is fitted correctly. Am I being a total n*b, what have I done wrong here? Thanks Rob. Quote
al-yeti Posted May 17, 2023 Posted May 17, 2023 4 minutes ago, garnayrob said: Hi, I've just hard wired a Pyronix DeltaBell (with backlight) to a Pyronix enforcer panel, but it's not working. It was previously working fine with the same panel at another location. This time, I have not wired the tamper circuit (I removed the switch), as it's up high and the fitting surface is not particularly great. I did a reset on the panel, so the Z33 for the tamper is not active. Endstation ouput/bell output is set to 014 / Siren Any. I've only fitted 3 wires as follows: STB on siren to STB on the panel Bell on the siren to Bell on the panel 12V+ on the siren to +12v on the panel When the alarm is triggered, the internal siren works fine, the outside siren does not. I don't think the comfort lights are active either? On the siren, the battery is enabled (J8 jumper is connecting pins 1+2) on INT and the sounder cable is fitted correctly. Am I being a total n*b, what have I done wrong here? Thanks Rob. What about the negative ? You still need it Quote
al-yeti Posted May 17, 2023 Posted May 17, 2023 Just now, al-yeti said: What about the negative ? You still need it Minimum you need is the Neg -ve Pos +12v - bell trigger And have the bell set to SCB mode , and make sure the bell tamper is correctly removed , I think you need the switch though for bell to work Quote
sixwheeledbeast Posted May 17, 2023 Posted May 17, 2023 The switch would usually have to be closed, it's not sensible disabling it really. If the sounder isn't suitable for the fixing surface then make it suitable or use a better bellbox. Quote
garnayrob Posted May 17, 2023 Author Posted May 17, 2023 Thanks everyone for the advice, much appreciated. Quote
