mikeald Posted December 20, 2004 Posted December 20, 2004 hi there, i am after a 24 volt AC radio receiver unit. It must have a set of contacts on it that go from normally open to closed once the user presses a remote button. (THIS IS NOT for an intruder system). And the contact MUST stay closed until the user presses the same button again to de-energise the relay. (Basically there is a gatehouse, press button once - barrier opens, press button again - barrier closes. (Can someone reccomend a particular reliable manufacturer? Working range must be up to 10 metres. many thanks mike Intruder & Fire Member
Guest Peter James Posted December 20, 2004 Posted December 20, 2004 Theres a relay made by ERL(available cpc or csd) called a very handy relay an AC or dc relay. Get two and wire as a JK flip Flop and bobs a very close relative. Pete
morph Posted December 20, 2004 Posted December 20, 2004 Rf Solutions specialise in this sort of thing, have a look here
mikeald Posted December 20, 2004 Author Posted December 20, 2004 excellent thanks guys Intruder & Fire Member
