kraftphone Posted July 9, 2023 Author Posted July 9, 2023 50 minutes ago, MrHappy said: the internet was designed for angry rants Ha Ha, yes completely get that, and it's true to an extent , nevertheless many companies on TrustPilot have excellent reviews. 52 minutes ago, MrHappy said: You probably don't have a maintenance contract Actually we did have one, paid a few hundred pounds for it from memory. Just found the new outfit rude and unhelpful. Always try to be polite and courteous , and expect same back. 54 minutes ago, MrHappy said: won't take any new ones on Interesting, thanks. We are considering binning the whole system and starting again, just reluctant to throw away the initial investment made. We almost have it working again, just need to replace a load of CR123 batteries. Quote
kraftphone Posted July 9, 2023 Author Posted July 9, 2023 For anyone else's benefit , think we have the final answer to why the Configuration Software will not connect. Below from the Risco FAQ section. Seems if the panel is connected to the Risco cloud via the IP channel ( and our panel is, with valid subscription ), the the Configuration Software cannot connect to the panel. Sort of reluctant to test / confirm this by disconnecting the panel from the Risco Cloud in case Risco then say " you can't reconnect , you are an end user etc etc" Quote
MrHappy Posted July 9, 2023 Posted July 9, 2023 16 minutes ago, kraftphone said: Interesting, thanks. We are considering binning the whole system and starting again, just reluctant to throw away the initial investment made. We almost have it working again, just need to replace a load of CR123 batteries. The control panels do odd things with age, defaulting & reprogramming can cure it (for a while) Alarm panels ain't consumer products, the manufactures are quite modest setups without the resources to support the end user, stuff like apps are under developed as they provide little or no income Alarm system aimed at the DIY market... lets say I'd rather have herpes than a Yale or ERA or whatever... alarm Quote Mr Veritas God
kraftphone Posted July 9, 2023 Author Posted July 9, 2023 8 minutes ago, MrHappy said: Alarm system aimed at the DIY market... lets say I'd rather have herpes So do the RING security systems have any known diseases ? https://en-uk.ring.com/products/alarm-security-5-piece-kit-gen-2-indoor-cam-gen-2 Quote
sixwheeledbeast Posted July 9, 2023 Posted July 9, 2023 It's ungraded DIY tat that sends all your data to Amazon? 1 Quote
al-yeti Posted July 10, 2023 Posted July 10, 2023 3 hours ago, kraftphone said: For anyone else's benefit , think we have the final answer to why the Configuration Software will not connect. Below from the Risco FAQ section. Seems if the panel is connected to the Risco cloud via the IP channel ( and our panel is, with valid subscription ), the the Configuration Software cannot connect to the panel. Sort of reluctant to test / confirm this by disconnecting the panel from the Risco Cloud in case Risco then say " you can't reconnect , you are an end user etc etc" Dude just use the alarm until you can't , why you need confin software to connect when you can manually do it all? I would say bin it you sound like a competent diyer .... Quote
MrHappy Posted July 10, 2023 Posted July 10, 2023 9 hours ago, kraftphone said: So do the RING security systems have any known diseases ? - infectious laughter ?? Local to me there's one on a "Jewellers", They must be uninsured as there will be a requirement to have a proper graded alarm holding a police URN to Intruder & Hold Up for the insurer to provide cover ? You needed graded equipment designed for the UK market, most the stuff the proper alarm co's use is sold to every tom, dick & harry... Having an expensive set of marples chisel dose'nt make any one a joiner 1 Quote Mr Veritas God
james.wilson Posted July 28, 2023 Posted July 28, 2023 Have a look at ring hq it won't have a ring system protecting it Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
MrHappy Posted July 28, 2023 Posted July 28, 2023 5 minutes ago, james.wilson said: Have a look at ring hq it won't have a ring system protecting it Yale ? Quote Mr Veritas God
james.wilson Posted July 28, 2023 Posted July 28, 2023 I'll let you do the stalking. At bell shape I'm going adt Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
