Mubeen Posted July 15, 2023 Posted July 15, 2023 I am having Flex 20 panel. In this i need to conenct 8 Door Contacts and 8 siresn. So i have done 3 outputs in the main panel. But when i start working on the RIO module, the 4 outputs in the RIO are not responding. I have tries Bells,Strobe,PA. But didnt work. Is there anything i am missing to enable the outputs in the RIO. The zones are working fine in the RIO, only problem is the Outputs. @Galaxy Guycould you please help?? Quote
sixwheeledbeast Posted July 15, 2023 Posted July 15, 2023 8 sirens? I would say the outputs are programmed incorrectly but can the panel even support all this stuff your trying to power. Quote
Mubeen Posted July 15, 2023 Author Posted July 15, 2023 17 minutes ago, sixwheeledbeast said: 8 sirens? I would say the outputs are programmed incorrectly but can the panel even support all this stuff your trying to power. Yes, in my case i have 8 door contacts...and 8 sirens(which i can give external power, since the panel doesnt have enough power to feed). So whenever any of the door contact opens, corresponding siren should ring. Yes, i know that flex20 has only 7 outputs maximum possible. So 3 i have already done in the main panel.Its working fine. But when it came to RIO with address 2, zones i a can monitor, but outputs, i can see any changes even after configuring them. Also while Testing ON/OFF doesnt work for the RIO Outputs. Quote
al-yeti Posted July 15, 2023 Posted July 15, 2023 7 hours ago, Mubeen said: Yes, in my case i have 8 door contacts...and 8 sirens(which i can give external power, since the panel doesnt have enough power to feed). So whenever any of the door contact opens, corresponding siren should ring. Yes, i know that flex20 has only 7 outputs maximum possible. So 3 i have already done in the main panel.Its working fine. But when it came to RIO with address 2, zones i a can monitor, but outputs, i can see any changes even after configuring them. Also while Testing ON/OFF doesnt work for the RIO Outputs. What are rio you fit ? Picture ? Quote
james.wilson Posted July 28, 2023 Posted July 28, 2023 I'd say your using external psus without commoning the negs? Bear in mind a rio can only sink 400mA also Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
