Polybear Posted July 29, 2023 Posted July 29, 2023 Hello, I'm searching for a new external sounder + strobe to work with a Paragon Plus wired alarm system, as the existing unit is faulty (the SAB module has died ) and to get into the box I'll have to butcher the cover as the new soffit is hard up against the cover so I can't remove it The Panel Spec. is as follows: BA: Negative Trigger B+: 12v supply B-: 0 volts BT Bell Tamper (-ve return) Max Current: 0.5A STB -ve: negative trigger STB +ve: 12v supply Max Current: 0.5A Is a Pyronix Deltabell a suitable option please, and if so which variant would be the one to go for - I notice there are Deltabell E, Plus and X on offer (have I missed any?) but am unsure of the difference between them (apart from price). Also, is there anything to be aware of regarding wiring? I installed and programmed the existing system myself so changing the box is fine - I just need a little guidance with a suitable unit as Alarm systems have moved on a little since the mid 90's.... Many thanks Brian Quote
PeterJames Posted July 29, 2023 Posted July 29, 2023 Hi Brian Welcome, any branded sounder will be suitable replacements, but the terminology used between brands is normally different. The paragon is an old panel and was made before Pyronix bought out Castle and so its likely the older panels will have different terminology then later products 1 Quote
james.wilson Posted July 29, 2023 Posted July 29, 2023 As above the panel is really old I'd check it's OK before bolting bits on 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Polybear Posted July 30, 2023 Author Posted July 30, 2023 Thanks for the replies; the panel is fine as it's regularly maintained/walk tested and upgraded as needed (eg new sensors). Cheers, Brian Quote
sixwheeledbeast Posted July 30, 2023 Posted July 30, 2023 Just consider permanently illuminated external sounders require planning permission, if the decal space is used. I would disable anyway. Make sure the controls are in full working order, charging rates, voltages etc; before only replacing the siren. 1 1 Quote
