Hello,
I'm searching for a new external sounder + strobe to work with a Paragon Plus wired alarm system, as the existing unit is faulty (the SAB module has died ☹️) and to get into the box I'll have to butcher the cover as the new soffit is hard up against the cover so I can't remove it ?
The Panel Spec. is as follows:
BA:  Negative Trigger
B+:  12v supply
B-:    0 volts
BT Bell Tamper (-ve return)
Max Current:  0.5A
STB -ve:  negative trigger
STB +ve:  12v supply
Max Current:  0.5A
Is a Pyronix Deltabell a suitable option please, and if so which variant would be the one to go for - I notice there are Deltabell E, Plus and X on offer (have I missed any?) but am unsure of the difference between them (apart from price).
Also, is there anything to be aware of regarding wiring?
I installed and programmed the existing system myself so changing the box is fine - I just need a little guidance with a suitable unit as Alarm systems have moved on a little since the mid 90's....
Many thanks
Brian
Hi Brian Welcome, any branded sounder will be suitable replacements, but the terminology used  between brands is normally different.
The paragon is an old panel and was made before Pyronix bought out Castle and so its likely the older panels will have different terminology then later products
  • Thanks 1
Just consider permanently illuminated external sounders require planning permission, if the decal space is used. I would disable anyway.
Make sure the controls are in full working order, charging rates, voltages etc; before only replacing the siren.
  • Thanks 1
  • Upvote 1
