john. Posted August 18, 2023 Posted August 18, 2023 Hi. I have a 9448 it is working perfectly all user functions work eg turn chimes on and off it sets, unsets everything good as far as user functions go. However if I try to get into engineer programing mode by 0, enter and my code it just beeps and nothing happens ie no flashing red leds nothing. It has had a recent new battery and that test good under load. I wonder if there is another code sequence I am unaware of I should try or is it new panel time. All help much appreciated. Thanks. John. Quote
al-yeti Posted August 19, 2023 Posted August 19, 2023 16 hours ago, john. said: Hi. I have a 9448 it is working perfectly all user functions work eg turn chimes on and off it sets, unsets everything good as far as user functions go. However if I try to get into engineer programing mode by 0, enter and my code it just beeps and nothing happens ie no flashing red leds nothing. It has had a recent new battery and that test good under load. I wonder if there is another code sequence I am unaware of I should try or is it new panel time. All help much appreciated. Thanks. John. Your engineer code is different from what your trying 1 Quote
john. Posted August 19, 2023 Author Posted August 19, 2023 (edited) Hi al-yeti. Thanks for the reply but I am using the code I programmed in, if I use a random code or, indeed the default engineer access code #### I don't get the beep so I assume I am using the correct code. Thanks again. John. PS I would try a reset but I'm worried that I would loose my settings and only the default settings would be available. Edited August 19, 2023 by sixwheeledbeast No codes in posts please Quote
