Starting to wire up the window zones (as previously discussed). My existing system (see photo below) had resistors across the common pin and zone pin (circled in blue), and a resistor in series with the windows (circled in red). That is because my current system is zone doubling.
I assume on the new galaxy FX100+ (because I am not planning on zone doubling) I just follow the diagram as previously discussed here in my Previous Post and will only need a single 1k resistor as per the one circled in red above?
Hate to keep asking, so please excuse my questions. Once I have my head around this for one zone I will be fine.
On 22/09/2023 at 20:18, james.wilson said:
Normally your final exit doors would be 'final' you entry route zones would be exit. The use intruder for the rest not on the entry /exit route
Thank you James, much appreciated.
Nice wiring....
Speaker wire?
31 minutes ago, al-yeti said:
Speaker wire?
It's a photo of the old system. Which explains why it's being upgraded. But yes, I can see your point.
48 minutes ago, MrHappy said:
dunno, TBH I couldn't give a Castlemaine 4x ?
Well, if you ever find yourself in a bar brawl with a kangaroo, at least you'll have a cold Castlemaine XXXX as a peace offering! ?
I appreciate the professional installers on this forum, and I understand that my situation may seem less than ideal. I want to assure you that I am doing everything I can to improve the current circumstances. This situation is not intentional, and if there were a straightforward solution, I would have implemented it already. However, there are some challenges that will require time and effort to address. Your advice and guidance are valuable to me, and I truly appreciate your support.
Thanks, Mark
  • Like 1
