Grego Posted September 30, 2023 Author Posted September 30, 2023 (edited) Have completed all the wiring and programming following the Galaxy Flex Installer Manual. All rio's and zones appear to be working. Did a full set test, which seemed to work ok. Upon reentering the home and doing an unset the following message came up on the keypad... Not sure if that is an issue? Was surprised to see the message? Pressed esc to get back to the standard banner. Also wanted to ask... is there any suggestions on doing a realistic intruder test (opening a door that is set as intruder) to see if the alarm activates? I want to try and do a test without the external siren/bell going off (neighbours might not like it). Mind you, I am thinking I do want to be sure the bell and strobe actually work. Edited September 30, 2023 by Grego Quote
james.wilson Posted September 30, 2023 Posted September 30, 2023 That's a walk test but you do need to test it and fire the external, signalling etc 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Grego Posted October 1, 2023 Author Posted October 1, 2023 18 hours ago, james.wilson said: That's a walk test but you do need to test it and fire the external, signalling etc Did a walk test, and a full set test, and the external siren/strobe didn't fire? So I figure there's something I need to turn on for the opt ports to work? Quote
Grego Posted October 1, 2023 Author Posted October 1, 2023 Turns out I had the Program Outputs Polarity (53.3) the wrong way around, it needed positive polarity and not negative. I also set Mode 53.2 to LATCH, which I assume is the default setting. So the siren appears to be working, both in bell test and a full set test. I am planning on replacing the external siren/strobe... so perhaps the professionals on here could recommend a suitable domestic siren/strobe. Quote
al-yeti Posted October 1, 2023 Posted October 1, 2023 1 hour ago, Grego said: Turns out I had the Program Outputs Polarity (53.3) the wrong way around, it needed positive polarity and not negative. I also set Mode 53.2 to LATCH, which I assume is the default setting. So the siren appears to be working, both in bell test and a full set test. I am planning on replacing the external siren/strobe... so perhaps the professionals on here could recommend a suitable domestic siren/strobe. Which ones are available out there ? Quote
Grego Posted October 1, 2023 Author Posted October 1, 2023 1 hour ago, al-yeti said: Which ones are available out there ? Give me suggestions and I can go from there. Quote
