Have installed an alarm in my shop. Texecom elite system.
we have a risco break glass sensor fitted onto the ceiling.
we have a double door system but when the door closes it tends to slam and this sets of the break glass sensor. Also there is a mag lock on the door and that locking also causes the sensor to go off
45 minutes ago, Hpatz1 said:
We have a motion sensor but if glass is broken this won’t set the motion sensor off
What kind of frames ?
Shocks could work provided no one bangs on the windows at night
DIY can't do Grade 3. Double Knock doesn't conform to any standard.
Motion detection fitted correctly can cover a window area if the window was broken.
Hence the question is a glass break the correct detection for the task, most often they are not.
